Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 10:07 PM   #1
gusguts44
gusguts44's Avatar
Vehicle: 3.8 Mustang 00'
Default Differential oil change
So im planning on changing my differential oil this or next week, but need some input. First my car has 140k miles and i dont think the diff oil has never been changed, would this be a good time to change it? and if i do, should i just remove the drain plug and put the new oil, or should i remove the diff cover, clean all around make a new gasket seal it up, then install the new oil. Im going with royal purple but i dont know what viscosity my car uses.
gusguts44 is offline   Reply With Quote
Old 11-02-2009, 10:17 PM   #2
fordforlife0225
Vehicle: 2004
check ur manual or local shop for viscosity. there is no drain plug there is only a fill plug. in order to drain it u have to either suck it out wit a straw like at the doctors office lol we had one at jiffy lube where i worked thats how i changed mine... or pull of the diff cover then put it back on and fill it up till a slow stream runs out the top
__________________
****2004 ford mustang 40th anniversary edition, v6****
-sct3 tune -cold air intake
-cobra rear sway bar -tru dual exhaust
-kyb shocks and struts -rockford fostgate 12" sub
****2007 kawasaki ninja****
Quote:
Originally Posted by SKAR View Post
Ive always made lavish clothing out of the baby seals ive clubbed.
Quote:
Originally Posted by 1987MustangGT5.0 View Post
If I had a vagina I'd be much more giving with it.
SEMPER PARATUS
fordforlife0225 is offline   Reply With Quote
Old 11-02-2009, 10:20 PM   #3
SKAR
Luzerator
1983 Ford Mustang
My Garage
SKAR's Avatar
Vehicle: 1983 & 1990
Pull the diff cover off completely, wipe it out a bit and put it back on, refill as fordforlife said....
__________________
SKAR is offline   Reply With Quote
Old 11-02-2009, 10:22 PM   #4
Fink
1999 Ford Mustang
Fink's Avatar
Vehicle: 1999 Ford Mustang
Make sure there is very very very little old gasket material on the mating surfaces between the diff cover and housing.
__________________
Mods:
MAC LT's & O/R H, ROUSH Side Exhaust, GT Rear Sway, SCT X3, Auburn LSD w/ 3.27's
Waiting:
Cobra Brake Kit Front and Rear
Quote:
Originally Posted by brian1570 View Post
now RS is gonna come in here and start sh!tting on his keyboard again.
Fink is online now   Reply With Quote
Old 11-03-2009, 03:19 PM   #5
Azrael
Azrael's Avatar
Vehicle: 01 SiXXXer Coupe
Send a message via AIM to Azrael Send a message via Yahoo to Azrael
75W-140 is what you want. I'd recommend Motorcraft though, since it is the OEM fluid. Also, it is nearly impossible to change rear end oil without removing the cover. It can be done, but you'd need that straw-like thing. Once the cover is off, scrape down the lip of both the cover and the actual rear end where the old gasket was. Then, when you put everything back together, apply high heat RTV silicone (wait approx. 4-5 mins for it to get REALLY sticky), followed by the gasket. Then, put a layer of RTV on the lip of the cover, and stick everything together. Wait about an hour, and get back on the road.
Hope that's....helpful.
__________________
Mods: FRPP T-Lok w/ 3.73 gears - Hurst T-Handle - MGW Short Throw - Cold Air Intake - Mach 1 wheels - Custom Straight Duals - WOT Mod - Custom Fuel Door - Rear Window Scoops - Panasonic Ghost Stereo w/ Alpine Type X Speakers - 3 MA Audio 10" Comp Subs
Coming Attractions: Cobra R 2000 Hood - Black FR500 Rims - HID's - High Lope Cam - Cut Springs - Stroked Motor
V - New pic needed...
Azrael is offline   Reply With Quote
Old 11-03-2009, 11:22 PM   #6
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
I took a scotchbrite pad to my diff and cover to remove the old stuff, get it all off and be very liberal when puting the new stuff on.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is online now   Reply With Quote
Old 11-04-2009, 09:06 AM   #7
RogerDodger1
Vehicle: 1989 Piece of Junk
Quote:
It it were my car, I would have changed the O.E. fluid in the differential as soon as the car was in the driveway. Failing that, I would have changed it at 50,000. 140,000 is way overdue. To remove accumulated metal particles and clean off the magnet inside the differential, (if so equipped), taking the differential cover off is the only way to do the job right. As for Royal Purple, I will hazard a guess that you haven't seen the gear lube white paper, "A Study of Automotive Gear Lubes", or you wouldn't be selecting that brand. Of the 14 different brands that were subjected to a battery of industry standard tests, RP failed several of the tests and overall tested out as one of the lower performing brands and in the final evaluation came in near dead last, yet they have one of the highest prices compared to the other brands of gear lubes.
Here is the link to the pdf file of the gear lube white paper. There's some darned good information here -
http://www.amsoil.com/lit/g2457.pdf
Here is the link to the online view of the gear lube white paper -
http://https://www.amsoil.com/comparison/gear-lube.aspx
As to the recommended viscosity of gear lube and quantity, it depends on which rear axle your Mustang is equipped with. Below is the link to the Amsoil My Garage look up that will tell you which viscosity Ford recommends and the quantity -
http://www.amsoil.com/products/appli...aspx?zo=349698
Your Mustang's rear axle could have 75W-140 or 80W-90 viscosity gear lube. It's important to use the correct viscosity to avoid wear damage. The look up guide says the differential for the Cobra R Mustang has a Ford recommended viscosity of 75W-140 and the other two differentials, (controlled slip and standard), Ford recommends 80W-90. If your car takes the 80W-90, the hot ticket in a synthetic gear lube is the 75W-90 viscosity and will provide better protection for your...rear-end.
It's also important to use a differential additive if your car is equipped with controlled slip or locking differential, so as to avoid gear-housing chatter noise.
With the eye opening test results of the gear lube white paper, I'd personally strongly advise you to select a different brand of gear lube. Might not make sense to pay more for less protection.
I hope this has been of help.
RogerDodger1 is offline   Reply With Quote
Old 11-04-2009, 09:37 PM   #8
gusguts44
gusguts44's Avatar
hey everyone thanks for the replies. I need 3.25 pts of 75w140, and im going with the AMSOIL. I was thinking of making a write-up but not sure yet. Some dude at work told me to spray break cleaner at the differential once the cover is remove to clean all the gunk inside. Once again thanks for the insightful replies.
Old 11-04-2009, 09:45 PM   #9
ShadyNinja
2005 Ford Mustang
ShadyNinja's Avatar
Vehicle: y2k v6 /2005 gt
Send a message via AIM to ShadyNinja Send a message via Yahoo to ShadyNinja
Quote:
the S197 stangs call for 75w140 the new edge cars can use 75w90
been there done that,
my 2000 v6 stang had 150k when I changed the fluid ( wayyyy over do) I needed carb spray (or brake cleaner) to remove the residue from the old fluid.
take a look
there was a black film that required the help of carb spray to loosen it up
so I thought I would share a few photos.
you can see the parts I have cleaned already
*another thing the Synthetic fluid hardly had a smell, if you have worked with conventional gear lube, you know what I'm talking about*
ShadyNinja is offline   Reply With Quote
Old 11-04-2009, 10:13 PM   #10
gusguts44
gusguts44's Avatar
take a look
Hey dude how long did it take you from start to finish.
1989, 2000, 2001, car, change, cobra, cover, differential, gasket, gt, mustang, needed, oil, posi, removal
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
