I am moving forward with my engine swap project, and have some compatibility questions. I know that the '99-'00 F150 4.2 V6's are a bolt-in replacement for the 3.8. That engine code is 2-255, and it can also be found in the E-150 van.
My question is, is the the 2-256 engine also a bolt-in swap? The F-150 motors from 2001-2008 have this engine code. This engine is found in:
Ford F150
Ford Van
Ford Freestar
Ford Windstar
Mercury Monterey
If the 2-256 engine is still basically a stroked 3.8 block with the same electronics, that would be a great list of vehicles to pull my engine from. Some of them were made as late as last year, which means low mileage motors are available. I have found a 40,000 motor from a Freestar for only $600, so if someone can verify it's the same mill, I'm buying it.
Thanks,
David
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
David SDRev.com ~ Driving San Diego
Race Car: '72 Datsun 240Z, Full Race
Show Car: '72 Datsun 240Z, 350 Vortec SBC @ 550HP
Drivers: '99 Convertible Mustang (dead), '07 Ford Freestyle, '02 Toyota Sequoia
Well the stripped down shortblock will work, you will probably need to change the oil pan to a 2001 stang pan.
If the splitport heads have gone unchanged you can also use those for a longblock.
For the lower intake, they differ between models and years so it is best just to swap in a 99-00 upper and lower and use your wiring harness.
There are a few other small things to take note of such as where the timing is set and the cps used and so on.
Will let you know how it goes. Thanks for the post.
__________________
