Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 11:56 PM   #1
tranceaddict
2004 Ford Mustang
Vehicle: 2004, ford, mustang v6
Default car won't start
I recently put in a 65 mm throttle body, I had trouble switching out the tps sensor, in the beggining it was lined incorrectly but I fixed it and i was having slight idle issues.
Today I was driving and I stopped the car and when I went to start it back up the starter would turn the engine over but the engine wouldn't start.
However when I pressed the gas pedal while trying to start the car, it started up.
Is there a problem with something in the fuel system? by the way I own a 2004 v6
Thanks for the help guys
tranceaddict is offline   Reply With Quote
Old 11-09-2009, 12:20 AM   #2
neo8222
2000 Ford Mustang
Vehicle: 2000 Mustang V6
TPS sensor
__________________
Quote:
Originally Posted by fordforlife0225 View Post
dude you are the yoda of subs
Mods:
Sniper Tune
Heads, Cam, Stroke, Port n Polish, 3 Angle Valve job (courtesy of the last owner)
Spec Stage 3 Clutch and Aluminum Flywheel
MAC O/R H-Pipe and MAC Flow-Paths(do your self a favor and DON'T GET FLOWMASTER 40'S!)
3 Inch Drop
AM Cold Air Intake
NGK Iridium IX (TR6IX) Plugs, Performance Wires
1500+ Watt Stereo- JVC,Kicker,Infinity
neo8222 is online now   Reply With Quote
Old 11-09-2009, 12:09 PM   #3
tranceaddict
2004 Ford Mustang
Quote:
Originally Posted by neo8222 View Post
TPS sensor
do you think its dead ? or is something misaligned or what?
Old 11-09-2009, 12:15 PM   #4
neo8222
2000 Ford Mustang
could just be misaligned since i starts and runs properly
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 11-09-2009, 12:25 PM   #5
tranceaddict
2004 Ford Mustang
it doesnt start properly, it try s to turn over but it wont start up unless i pump the gas pedal almost like a carb engine.
Old 11-09-2009, 12:40 PM   #6
neo8222
2000 Ford Mustang
oh, in THAT case sounds like the TPS is bad, but has spots where it works so when ur pumping it you hit that good spot and it gets the signal.
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 11-09-2009, 12:44 PM   #7
tranceaddict
2004 Ford Mustang
alright that sounds resonable. just one more question. when i first installed it, it worked fine. why would it all of the sudden just die?
Old 11-09-2009, 03:35 PM   #8
neo8222
2000 Ford Mustang
the metal workings inside them get brittle from the cold hot cold hot cold hot cold cycle of the engine so had you not touched it, it may have lasted for who knows how long. but sometimes the inner workings wear out to the point that taking them off and moving it around breaks it. happened to my friends trans am only with his pickup coil. took the distributor out to reset the timing at top dead center and realign the distributor and the pickup coil broke cause we moved it.
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 11-09-2009, 07:23 PM   #9
tranceaddict
2004 Ford Mustang
alright i will change it. is there a specific way to align it?
Old 11-09-2009, 07:24 PM   #10
neo8222
2000 Ford Mustang
there shouldn't be but one way to install it although before you replace it you could take a multi meter and check it with the ohm scale you should get a reading at all points of the throttle position.
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
car, position, start, throttle, wont
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
