Mishimoto Slim Radiator Fan
Hey guys I have a question about this product and I am wondering if this has everything I need to replace my fan assembly. Thanks in advance.
http://www.americanmuscle.com/mishim...iator-fan.html
Thanks!
Thanks!
RE: Mishimoto Slim Radiator Fan
The Mishimoto Slim Radiator Fan is a universal fit for applications that require high flow and clearance. The fan will attach to most radiators, but you will need to wire it. The motor only has a positive and negative wire, so it will need to be wired into your stock wiring if you have an electric fan already, or you will need an aftermarket sensor/switch/power hook up if you are currently running a Mustang with a mechanical fan.
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
