Wheel fit question
Wheel fit question
I will have a 2012 GT with Brembo & 3.73 this Friday. I’m shopping around for a winter wheel to put some Michelin X-ice Xi2 235/45R18 tires on. Would the below GT500 wheels fit my car with the Brembo brakes? I’ve had mixed responses from other members so I thought I would go straight to the source. Thanks
http://www.americanmuscle.com/black-...18x9-9410.html
That's a great purchase you just made, although I would not personally drive it in winter, that is certainly up to you!
If you wanted to use those wheels, you would be just fine! They are the same specifications as the OEM GT500s and will clear Brembo calipers, no problem!
I ran across a VERY nice 1993 Legacy turbo sedan, with a bad wheel bearing/axle for that price, but in the 1 day it was posted and I went to see it in person, it had sold.
I would suggest looking at older(pre-1998ish) subaru legacies or imprezas. They are AWD(most of them) and basically bullet-proof. That and all subarus basically share the same parts, so maintenance is cheap and as far as safety goes, there isn't much out there that will perform better in a crash! Be weary, though, it will be like going from a formula one car, to a peddle-kart. The naturally aspirated ones are sloooooooooooooow.
It's a lot easier to justify buying new wheels, to keep your originals clean in case you ever wanted to sell the car, rather than swapping tires over every fall-spring only to possibly damage the wheels that originally came with the car.
It's up to you, though!
NorthAmericanTuning
11-09-2016 11:44 AM
