2015-2016 Mustang Eibach Sport-Plus Suspension Kit (GT) Review
Lower your ride and improve handling with the Eibach Sport-Plus Suspension Kit for your Mustang GT. This suspension kit comes with front and rear adjustable sway bars and Eibach's sport line lower springs. http://www.americanmuscle.com/eibach-...
Improves Handling: Improve the handling of your S550 Mustang by upgrading to an Eibach Sport-Plus suspension kit. This kit is engineered to lower your S550 Mustang's center of gravity as well as reduce body roll which results in reduced squat during acceleration, superior handling, flatter cornering and better stability in any aggressive driving situation.
Improves Appearance: Not only does this Eibach Sport-Plus Suspension Kit improve the handling of your S550 Mustang, but it also improves it's over all appearance by lowering the ride height to get rid of that lifted 4x4 look that they roll out of the factory with for a more aggressive stance.
Complete Kit: This Eibach Sport-Plus Kit comes complete with Sportline Performance Springs, a 1.375" (35mm) front tubular sway bar, a 0.98" (25mm) rear tubular sway bar, brackets, grease-able polyurethane bushings and all the required installation hardware.
Eibach Sportline Spring: Eibach's Sportline Springs feature a proprietary progressive design that provides the ultimate balance to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. Estimated Drop: just over 1.0”.
Eibach Sway Bars: Eibach manufactures their Anti-Roll Bars from cold-formed, high-strength aircraft-grade steel for precision performance. Both the 35mm tubular Front Sway Bar and 25mm Rear Sway Bar are 3-way adjustability which allows you to fine tune the handling of your S550 Pony to suite your personal driving needs - from mild to wild. Both are completed in a red powdercoat finish for great looks and long life.
Application: This Eibach Sport-Plus Suspension Kit is specifically designed for use on all 2015-2016 GT Mustangs.
Fitment: 2015 2016
Item #384462
MPN# 4.14535.880
DerekShiekhi
04-11-2016 03:43 AM
one_focused_svt
03-09-2006 03:10 AM
05STANGonDAVINS
07-18-2005 02:55 PM
