Mach 460 Vs. Normal
Old 03-10-2004, 04:27 AM
HAUS
HAUS's Avatar
Default RE: Mach 460 Vs. Normal
i think he will be fine just installing the head unit. i believe in 2000 you couldnt just change the head unit. you would have to change the whole system for it to work. im not completley possitive but i think you should be ok. just do a little more research by contacting ford before you buy anything. let us know how every thing works out.
HAUS is offline
Old 03-17-2004, 07:34 PM
k8ieGT
k8ieGT's Avatar
Yes Im sure I have a mach 460. It HAS a cd player, but it doesnt play right..It was take them, make a clicking noise, and then spit them back out. So i need a new one i think..unless there is a way to fix it? Its a 95..
k8ieGT is offline
Old 03-30-2004, 11:52 AM
pichinco
pichinco's Avatar
CD was an adder on the '96's. Mach 460 or not. Not sure about the other year models.
pichinco is offline
Old 04-02-2004, 10:07 PM
tyybo
tyybo's Avatar
you dont actally need to bypass amps, just wire in the remote off the amp to the remote on your car. and my 95 came tape deck also
tyybo is offline
Old 04-05-2004, 06:21 PM
JJ94GT
JJ94GT's Avatar
just buy a mach 460 head unit, i went through weeks of torture tryin to install subs, when i finally realized all i needed was one dumb part. by stock radio, if u want subs you dont need an aftermarket one.
JJ94GT is offline
Old 04-05-2004, 06:25 PM
JJ94GT
JJ94GT's Avatar
and k8ieGT, are u tryin to play burnt cds? i find it real hard to play certain discs, my mix cds wont play in my deck unless they are TYC brand, and i think PNY Technologies makes blank cds that Mach 460 head unit likes. but mine does that too, it clicks and spits burnt cds out, not of those brands. i also get problems when its real cold inside the car, the disc wont play right away. but i think im better off waitng for a minute than re-wireing all the stock speakers, or gettin new ones.
JJ94GT is offline
Old 04-27-2004, 01:58 PM
GIGM08GT
GIGM08GT's Avatar
I am new but I have done some searching and sdiscovered a website that sells some type of converter for about 60 bucks. You can add an amp or add a new head unit. Its a cool site. Very helpful http://www.mustangaudiosystems.com/M...udio_page2.htm
GIGM08GT is offline
Old 05-08-2004, 01:33 AM
Marc_03GT
Marc_03GT's Avatar
I would stay away from those 10" sub encosures they are selling though...they are too small for the 10" (the 10" will fit but there isn't enough air in the box for the speaker to really perform.
-Marc
Marc_03GT is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
guitarman376
09-30-2015 05:54 PM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: Mach 460 Vs. Normal
