'06 Fuse Box and switched power supply?
Is there a slot in the fuse box that is switched? (turns on and off with ignition)
I'm trying to hook up the remote turn on wire for an amp. I know I can pull the shaker 500 head unit and connect to that wire, but I'm trying to avoid pulling the HU just to splice into a wire.
Is there another switched wire I can splice into that's easier to get at?
Thanks,
Steve
Thanks,
Steve
RE: '06 Fuse Box and switched power supply?
ORIGINAL: praztek
On the fuse box "passenger side" which one of the three available slots can I tap into which will power up upon ignition?
Thanks
Thanks
Open fuse slot #5 on the passenger fuse box is switched with the ignition. I have my remote amp turn on wire connected to that slot and everything works like it should.
