Mach 460 amps
Mach 460 amps
Does anybody know where the Mach 460 amps are in a 2001 GT convertible? I have a write-up to splice into the wires there, but it is for the coupe, and I don't see how the amps can be in the same place (under rear deck). Thanks for the help.
RE: Mach 460 amps
They Should be located behind the rear seat
You have to take the bottom of the rear seat out then the top part of the rear seat They are located directly behind the top part of the rear seat you can also see the convertable motor there also
RE: Mach 460 amps
they are small, underquality amps so all 4 can fit on the same amp rack where only two regular decent amps would go
but yes... if you have fold down rear seats just pull the seats down.... they'll be right there... if not... climb in the trunk and you'll get to them on the upper part of the back section of the trunk.
RE: Mach 460 amps
its a vert it will be a whole lot better to take out the rear seat if your going to replace the factory electronics it is going to be much easier this way but yes it can be accessed through the trunk if you weight 20 pounds and are 3 foot tall
breaking
10-02-2015 01:27 PM
