Interferance sound
Old 09-10-2009, 01:10 AM
Fink
Fink's Avatar
Default Interferance sound
I was switching out my amp with a friends amp. I had everything switch over in his car but the subs wouldnt work. I tried everything to make them go but it wouldnt happen so I put his amp back in. I was tightening the power wire to the amp when I kinda touched the metal on the amp and a spark flew. After that the rear speakers make a humming sound whenever the power wire touches where it should be connected. It only happens when its connected and the amp is on. What would cause this?
Also the subs keep cutting in and out but only when you fiddle with the wire. I am going to get a connector tomorrow to see if this fixes it, its just bare wire right now.
Friends car is a 04 Grand Am GT. Aftermarket HU and 6x9's, Kicker I believe.
Fink is offline
Old 09-10-2009, 08:06 AM
Shadowc
Shadowc's Avatar
Few things possible..
Shorted the amplifier out
or back fed the amp thru the rca wich then blew the rca out put in the radio.
Unplug rcas from amp and turn it on see if the noise is still there if so then you shorted the amp out.
If not then you possibly blew the rcas on the radio,, Any chance the radio is a pioneer if so you can fix it easy
Shadowc is offline
Old 09-10-2009, 09:55 AM
Fink
Fink's Avatar
Actually the HU is a Alpine. But the RCAs arent hooked into the subwoofer outputs, can I just switch it over?
Fink is offline
Old 09-10-2009, 10:28 AM
Shadowc
Shadowc's Avatar
If the amp is hooked to the 6x9's? then no you cant connect it to the subwoofer rca out, only front/rear out puts.. also the rcas are all interlinked internally so just movin them over wont do anything either
Shadowc is offline
Old 09-10-2009, 12:38 PM
Fink
Fink's Avatar
Ok. The 6x9's are not hooked to the amp.
Fink is offline
Old 09-10-2009, 12:46 PM
Shadowc
Shadowc's Avatar
Ok then that case you can try the rear out put of the radio
Shadowc is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Quick Reply: Interferance sound
