Can the speakers on a MACH 460 be replaced with off-the-shelf ones or not?
Can I replace just the speakers of the MACH 460 system? I thought I read something somewhere that said the interface is non-standard. Has anyone replaced just the speakers with aftermarket ones?
RE: Can the speakers on a MACH 460 be replaced with off-the-shelf ones or not?
ok, the ohms or resistance is different but you can safely run aftermarket speakers. i want to say the factory setup is at a 6 ohm load, which means that standard 4 ohm speakers will bring the amp down and it will get hot. there are 8ohm speakers on the market that you can use, but inturn you will lose a little power. you can get around that using a combination of a mid and tweeter and running each side in a series with 4 ohm speakers which will bring you up to a 6ohm load and the amp will be fine. best bet is to lose the factory amp and speakers and go with a good 4 channel and set of components and two ways in back
