Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-14-2006, 04:34 AM   #1
angelgabe
Default Wiring Diagram for Shaker 500 PLEASE!?
I'm desperately trying to find a wiring diagram for the radio and the amps/speakers in the 2005 Mustang GT with the Shaker 500.
What I'm trying to do is keep the Shaker as it looks sweet but integrate an Audio Control EQS into it. The EQS is capable of converting speaker level, signal level or rca inputs into 13volt preouts for up to 6 channels. All 6 channels are fully tunable with line level in, and signal output control, equalizers, and crossovers. Its really a nice unit.
What I'm trying to figure out is how to get the signal from the headunit into the eqs, tune it, then send from the amps directly to the speakers while bypassing the factory amps. I also want to keep the in door subs working if possible and I want to know if anyone has any specific info on them, like the impeadance and frequancy range ie. are they capable of handling full range or not. Also, are the tweaters and midranges (I'm assuming these exist from what I'm reading, I don't know for sure whether they're compononts or not) are passively crossed over or if this is done actively from the HU or the amp, and what are their respective impeadances?
I only get one crack at this so I don't have much room for trail and error.
Thank you for your help!!!
__________________
The best way to do it is yourself.
angelgabe is offline   Reply With Quote
Old 12-14-2006, 05:12 PM   #2
ST4NG
Default RE: Wiring Diagram for Shaker 500 PLEASE!?
You will be able to keep the factory subs working if you do not disconnect them and keep the factory amps hooked up.
I haven't looked at the stock speakers yet, so I can't recall if I read that they are amplified by the amps or not. But if they are, your wiring might get very tricky.
ST4NG is offline   Reply With Quote
Old 12-14-2006, 11:03 PM   #3
angelgabe
Thanks for the info. I wonder what the LP crossover frequency is for them.
__________________
2006, 500, diagram, mustang, shacker, shaker, wire, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
