'06 Coupe - Best place to securely mount amp & sub?
Old 01-24-2007, 12:48 AM
Myy06
Myy06's Avatar
Default '06 Coupe - Best place to securely mount amp & sub?
Hey everyone, I made it past the hard part and just installed my Avic-Z1, siruis satellite, and hardwired my Valentine V1 while I was at it (my first ever audio install with the help of the online community)!
So now I have a Sony Xplod 1200w 2 chanel amp bridged to a single 10" Alpine Type R sub in an enclosed box. A guy at Best Buy wanted to charge me $80 to mount them securely (everything is already wired and sounds great). He suggested the amp mounted to the rear seat (well I can do that) but what is the best way to securely mount the heavier sub?
Thanks!
Myy06 is offline
Old 01-24-2007, 01:11 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Default RE: '06 Coupe - Best place to securely mount amp & sub?
For good sound, I would look into facing semi-forward or sideways in the rear corner of trunk. Thatshouldgive you good bump, and keep thearea just behind theseat clear. I am not aware if the'06rear seat foldsdown to get to the passenger compartment, but if it does, that is always a good thing. As far as the amp, I am not familiar with the'06 (as mentioned above) so someone else canchime in on that one.
Jazzer
Jazzer The Cat is offline
Old 01-24-2007, 02:14 PM
SemperFi789
SemperFi789's Avatar
i have the d2 in my car with the type r 12 inch and my amp is screwed into the back seat. also i dont have the sub box secured in but i have it on a rubber mat that it really hasnt moved from since i put it in. its facing the passenger compartment
SemperFi789 is offline
Old 01-24-2007, 06:02 PM
Myy06
Myy06's Avatar
Thanks for the input so far, I was also thinking of bolting the amp to the rear of the seat. I tried the rubber mat trick and the mat I"m using isn't holding it in place. So far I have the sub facing sideways in the truck, seems to sound pretty good in that direction. So the amp is taken care of, now I need to find a respectable way to bolt down the sub... I don't want to think twice about accelerating hard out of a corner. [sm=gears.gif]
Any suggestions as to how a professional installer might do it? I found home depot metal brackets that could be bent into an "L" shape and bolted to frame near the rear taillights, as well as to the top of the sub... but that sounds a little questionable. It has to td othe job and look inconspicuous!
Thanks!
Myy06 is offline
Old 01-25-2007, 12:21 AM
Jazzer The Cat
Retired Moderator
If you find a permanent home for sub, I would take out the speaker., and run a screw throught the bottom of the box and into the floor. Just make sure you confirm not wires or gas tank below [sm=badbadbad.gif]
jaz
Old 01-25-2007, 10:43 PM
laserred38
laserred38's Avatar
not an S197..but my sub box (two 10" type Rs not one) is bolted to the bulkhead right where the seat latches are...two L-brackets as mentioned above...bolted to top of box and to the bulkhead...simple as PIE...i had to unbolt them to slide my box around to get to my rear shocks when i lowered my car...simple 4 screws and it was out...the box does not move at ALL
laserred38 is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
09-16-2015 07:53 PM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
Quick Reply: '06 Coupe - Best place to securely mount amp & sub?
