Cause the "premium" system SUCKS! I've already purchased the amplifier to run the whole system.
What I don't know is what size speaks the car has. I have the premium system, so no subs in the lower doors. Only whatever is behind the upper grills. I have Boston Pro series separates in my truck and love them but thinking of going with something else for the car. I'm considering the same setup in the car, with mids in the doors and tweets on the pillars. Just something other than Boston brand.
Can someone tell me what the speaker sizes for the doors and rear in the new S197's are? Also does anyone know of any problems with resonance, etc in the doors of these cars that may require sound matting? And any problems with speaker depth in the doors?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
I did hit crutchfield last night. According to their "outfit my car", it lists 5 1/4' component systems as well as 5x8's. I figured the 5 1/4' seps would go in the front doors/pillars and 5x8's in the rear.
Ihave a Rockford Fosgate Power 1000 amp. It will apply 100 watts x 4 into 2 ohms and 600x1 for my sub/s. So I figured to parrallel wire the front/rear seps and some full-range 5x8's for the rear.
I'm assuming they also have speaker adapter kits that will adapt the 5x8's to 5 1/4, if needed.
Oh yeah and my budget for front seps is around $500. Maybe <$200 for the full ranges in the back. I plan to attenuate those anyway, so it won't matter if they're not as quality pieces as the front.
__________________
Honestly, with 6x8's it is really easy to make your own adapter and mount 6.5's. You will be much happier with the midbass response of a 6.5 then a 5.25. I would recommend using a full comp set for the front and ditch the rears. If you must have rears, make sure if you have comps, that you remove the tweeters. The last thing you want is full range rear fill destroying the sound stage your nice front stage creates.
I wish I would have checked back on this forum b4 going and purchasing the rest of my system today. I did purchase everything from woofersetc although I went with a little diff direction than your suggesting. After mucho research (and a talk with my local installer on what will fit), I pulled the trigger on these Morel Dotech Ovation 6 compsfor the front:
I did look HARD at the CDT's but their decent models fell a bit out of my price range for the seps (around $600 for the HD series). And from past experience, I know that you can never go wrong with Morel. They also have a low mounting depth that should help with the doors in these new mustangs.
The rear was another story. I figured I better play it safe and just get some quality coaxs that fit. Decided on these:
I'm just using the Boston'sfor rear fill anyway so I don't think it will be a big deal. My subs will be 2 10' Kicker Solobarics. I've been told by audiophiles that these subs suck and are $hit for sound quality, but I have two of them in my truck and think they kick ass. We'll see. I know I went with the best on the amp and front seps. We'll see how the boston's and kicker subs work out.
I do like your suggestion of going with some midbass in the rear. I may give that a try if I'm unimpressed with the staging.
__________________
And it kicks ass too. NO mobile sound system should be w/o at least 5 bands of para-eq in my opinion. I'm really trying not to rape anything fromthe system in my truck , but I'm REALLY thinking of snatching out that Kicker KQ-5....
Maybe I'll just get another one. It's worth every penny of $170.
If I can just figure out a place to mount it... keeping my old stock HU for stealth purposes..
__________________
This is cheaper and I have heard nothing but good things about it. I plan on going with this if I decide to get a EQ: http://www.cardomain.com/item/CLAEQS746
IMO, an eq is usually a bandaid for a poor isntall and thats why I don't have an eq in any of my cars.....
I even have my HU set flat.
Those that are truely hardcore will get out a scope and a mic with a couple hundred band eq to make sure frequency response is flat, but I'm not quite that much into SQ yet.
You made a great choice going with morel, they make some very nice audio equipment.
Soundstream products used to be top-notch back when I was really into car audio about 10 years ago. I'm seeingthat things have changed a lot, some of the really goodcompanies have been bought-out by other not so good companies and are now crap. I think SS may be one of them...
__________________
