Stereo Install Troubles
Old 11-11-2007, 12:27 AM
jitsbilly
jitsbilly's Avatar
Default Stereo Install Troubles
In the process of installing a new head unit ( Jensen Phase Linear) in my 2001 GT, Has the MACH 460 system. Unhooked the stock head unit and had to unplug 2 plus from the back of the unit. New unit only uses one of the plugs. When I turn the system on it doesnt sound like the amps are on. What am I doing wrong or better yet what do I need to do?
jitsbilly is offline
Old 11-11-2007, 01:02 AM
VTX
VTX's Avatar
Default RE: Stereo Install Troubles
You need to use both plugs. If you only use the main one then you are only powering your tweeters. The second smaller plug is the amp turn on and grounding to your mid-woofers. You need to get both plugs, and connect the blue/whites to the switch input/remote off the back of your aftermarket.
VTX is offline
Old 11-11-2007, 02:03 PM
Dave5point0
Dave5point0's Avatar
Just throw the jensen in the garbage and buy a pioneer or alpine, trust me i pull garbage out of cars all the time
Dave5point0 is offline
Old 11-11-2007, 06:05 PM
ttocs
ttocs's Avatar
you will need to buy a hrns that will plug into the hrns's that you unplugged, and then wire those into the hrns that you have for the radio. I am sure somebody has the hrns model # that you need, don't let BBY sucker you for the $50 hrns.........
ttocs is offline
Old 11-11-2007, 07:32 PM
VTX
VTX's Avatar
The harness you need is made by Metra. Model # 70-5519
VTX is offline
mtgldr
02-03-2024 09:00 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Ford_Dude
09-15-2015 03:25 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: Stereo Install Troubles
