Speaker Popping Problem
Tonight I had an In-Dash DVD Player installed. My car (2008 Shelby GT) came with the Shaker 500 sound system. I replaced the head unit only and left the rest of the stereo in tact. Now when I start the car and the DVD player starts up, the speakers make a single pop before the music starts playing. I had the same head unit in my 2004 Mustang with the Mach 460 system and I did not have this problem.
The guy who did the installation said that since I upgraded the head unit that it's perfectly normal for it to pop when the car is turned on. I think he's full of **** and can't figure out what's going on with it. I am afraid that it's going to cause damage to the speakers that are in the car so I'm afraid to turn it on. Once it's on and going, it sounds great, but I'm afraid that I'm going to cause damage to the speakers. Anybody have any advice on what the problem is and how to get it fixed?
RE: Speaker Popping Problem
the stock ford amps use a 5v turn on, not the 12v that every other deck out puts out. It is not a big deal, and will not hurt anything. The forum stick shows the proper way to wire up a voltage regulator, or you can also put a 1.5k ohm resistor in series with the remote turn on
ORIGINAL: ttocs
That makes sense, but I used the same exact deck in my old car and it never made the popping sound when I started it up, why would it do it in my new one? Or did the guy who did it the first time know what he was doing and the 2nd guy was a dumbass?
I took it back to them today and they said the reason why it's popping is because the amp for the 8" subwoofers in the front doors are kicking on before the head unit so it's making the speakers pop and the only thing they can do about it is disconnect the subwoofers altogether.
Here is the answer/link to your problem. I know this may not be your head unit, but it is your problem. Print this out and take it back to them and have them to fix it. And then tell them you are not going to charge them for the training.
Link: https://mustangforums.com/m_3581800/tm.htm
ORIGINAL: andysm
