Rear tail lights and mach 460/1000 Tweater question
okay in my 95 v6 stang the tail light dont come on but brake lights work... i havent gottin chance to check the bulbs out... but i gunna see if my new tail lights worked... mby its just bulbs what you guys tihnk?
and... whats the difference between the 460 and 1000 if i put 1000 in my car... will it work fine or do i need the mach 1000 amp and such?
Also where cna i get wiring for the radio i need isntall my cd deck... But most stock wiring is missing not sure what year's will work in 95 v6 stang.
it could be a fuse, could be a buncha stuff really but you should start simple and the fuse box is easy.
The 1000 is a completely different system that takes up the entire trunk. It does sound better but I would not sink money into factory stereo equipment unless you want to keep it stock looking.
inyadreems
08-21-2015 09:10 AM
