Need some help fellas
Ok, picked up a raptor from Tom in his garage sale and have been working on installing it. I ran a fuse tap out of the passenger side fuse bog for my hot wire to a switch in my console. Tapped the coil, saudered all my connections. The switch i'm using requires a ground so I did that and went to finish the ground wire for the raptor but that caused my switch (it has a light) to go dead, i'm on electrician but I'm guessing I only need one ground. I know I'm getting power and to the Raptor itself, but I've got a problem either with my connection to the coil itself or grounding the Raptor.
Any help would be appreciated it, I searched through quite a few threads but no one's done anything like this that I've seen.
Tapped what coil?
an electrition? No offence but the worst hack jobs I have ever seen were done by electricians and mechanics. I have a decade of audio/security experience and I promise I am the last person you would want wiring your house. know your limits......
No no no, a Raptor is a shift light. Simple enough but I made it difficult with my cut off switch idea. Out of the box it has ground, power, and your coil (line senses so it knows when to flash for the shift). I added a switch on my hot line so that if I didn't want to look at it I could cut it off but it's not lighting. Still trouble shooting, can't figure it out. I have no problem doing this kind of work it's not over my head, just trying to figure out what I overlooked.
