speaker
Old 01-10-2009, 11:46 AM
jtfrog
jtfrog's Avatar
Default speaker
Any other place to buy the 6 x 8 door speaker for the mach 460
jtfrog is offline
Old 01-10-2009, 12:10 PM
flood41
flood41's Avatar
go aftermarket.
flood41 is offline
Old 01-10-2009, 01:26 PM
ttocs
ttocs's Avatar
not really. The mach woofer is an 8 ohm woofer and replacing it with a standard 4 ohm full range speaker will not do. The closest I have seen was a 4 ohm dual voice coil speaker but even then it is not the greatest. If you have replaced the deck then you can slap what ever you want in there if you bypass the amp which is easy to do.
ttocs is offline
Old 01-10-2009, 01:46 PM
flood41
flood41's Avatar
the last ones i changed out were 4 ohm
flood41 is offline
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
Doogie65
09-06-2015 02:55 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: speaker
