hook up the blue wires. Your not turning the factory amps on. The subs will make a loud popping noise when you turn the radio on and off and it is covered in the forum sticky how to stop that.
look on the wires on the factory connector hrns and there will be small writting on the wires telling what each one is, look for the amp turn on which should be blue but could also be blue/white depending on brand.
Now depending on what deck you have it will have a blue amp turn on/power ant wire, or may have the two seperated into blue and blue/white. Check your manual and connect the remote turn on or amp turn on to the wire we found on the factory connector hrns.
