new amp or fix current amp?
My battery kept on getting a parasitic drain when the car was off, thus killing the battery in about down to about 11 volts in 2-3 days. I took it to a automotive electrical shop and it turns out that my pass. side amp in the trunk is malfunctioning somehow draining down the battery. They disconnected it and everything is fine now (as far as charging is concerned).
I have the stock Mach 460 system. I can get a "good" used amp from a wrecked Mustang off ebay for like $50. Should I do this or take the amp itself apart and try and fix it.?
Any help would be appreciated.... thanks.
Would replacing the amp fix the problem?
jwog666
12-27-2021 08:09 PM
