Installing an Avic D3 into a 04 GT
Old 02-02-2009, 10:08 PM
TorchRedGT04
TorchRedGT04's Avatar
Default Installing an Avic D3 into a 04 GT
I will be installing a avic D3 into my car sometime this spring, and I have a few questions. Now I have this same headunit in my 06 Explorer that I installed and it works perfectly I also added the radio shack voltage regulator due to the fact that I had popping when the stock amps turned on.
Now with the Mustang, I have the Mach 460 sound system and I plan on keeping the factory amps, but I want to add another amp for my subwoofer that I plan on putting in. This is the wiring harness that I plan on using.
http://www.crutchfield.com/p_1207055...e-Harness.html
Will I need a voltage regulator for the Mach sound system?
Also when I hook up the RCA cables coming from the crutchfield harness do I hook them up to the sub output to the headuint? When I install my added amp can I just split them using a y-connector?
TorchRedGT04 is offline
Old 02-03-2009, 11:33 AM
ttocs
ttocs's Avatar
you sound prepaired. You will need a voltage regulator, or you can also use a resistor to knock the remote turn on V down.
I think You do want to hook the rca's to the decks sub output, and you can use a Y cable if you add a sub later. I say I think because the wiring changed between the old and new systems between yours and mine and while the equipment is the same the hrns's are different. I show how I put a deck in on page 2 of my cardomain page and I bypassed the amps for the tweeters and needed to take the bass out of them to make them sound good. That hrns has speaker wires as well as rca's so I am not sure which is which.
ttocs is offline
Old 02-03-2009, 03:08 PM
TorchRedGT04
thanks, will I need some sort of bass blockers so that the tweeters work if I don't bypass the factory amps?
Old 02-03-2009, 07:50 PM
ttocs
ttocs's Avatar
I think the factory amp will cross them over and keep the bass out. If not these are a couple of bucks each, one per speaker needed and it can be added. IF the tweeters have bass going to them and are distorting then you can add them
ttocs is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: Installing an Avic D3 into a 04 GT
