Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-14-2009, 09:25 PM   #11
billyjacoby
Vehicle: 1997 Mustang GT
I'm having the same exact problem with my 1997 Mustang GT. It has the same system and everything, I originally had the stock deck in it but changed it to a pioneer deck hoping the problem was in the deck but I'm having the same problem.
And I just checked all of the fuses that are supposed to be for the radio and found nothing. There's another thread on this but it died about a month ago:
http://mustangforums.com/forum/audio...ease-help.html
Anyone have any ideas?
billyjacoby is offline   Reply With Quote
Old 07-15-2009, 10:19 AM   #12
ttocs
1994 Ford Mustang
ttocs's Avatar
You didn't listen to my instructions about the fuses in that post. Until you do I am not going to give you the next thing to check.......................................
__________________
http://www.cardomain.com/ride/2395420
ttocs is offline   Reply With Quote
Old 07-16-2009, 07:29 PM   #13
billyjacoby
So I pulled and checked every single fuse in my car and everything is fine. I took out my rear seats to try and see if that could help me see anything better, and it did but I couldn't find anything wrong with it. I would say that maybe the amps are just blown except for the fact that I lost all sound from all four speakers at the same time, so both amps would have had to blow at the same exact time and thats highly improbable. Anyone else have any other possibilities? I'm at a loss.
Old 07-16-2009, 11:11 PM   #14
ttocs
1994 Ford Mustang
ttocs's Avatar
checked the fuses under the hood too right?
I would probably look at the back of the radio next. Make sure all the harnesses are plugged in nice and tight. Give them a "jiggle"(techniacal term) while it is powered and see if it makes any difference. Do this with the connections at the amp as well.
__________________
Old 07-21-2009, 04:29 PM   #15
srasm950
Vehicle: 1998 Ford Mustang
I did all that too. I checked each fuse, under the steering wheel and under the hood, and all were fine. I also checked the connections on the back of the head unit as well as the amps, everything was connected and tight. I'm not sure what else it could really be. Any other ideas would be very helpful. Thanks a lot
srasm950 is offline   Reply With Quote
Old 07-21-2009, 09:51 PM   #16
ttocs
1994 Ford Mustang
ttocs's Avatar
the next thing I would do then is check for power at the amp. I don't know what wires to check other then they are usually a little thicker, but turn the key and deck on and check each wire. You should have one wire that has +12v on it constantly and one that will switch with the deck to 6v.
__________________
Old 07-22-2009, 05:33 PM   #17
srasm950
Forgive my ignorance, but I'm pretty new at a lot of this. How do you go about checking the power of the wires?
Old 07-23-2009, 12:35 AM   #18
ttocs
1994 Ford Mustang
ttocs's Avatar
do you have a volt meter or test light? I would guess no huh? I am not trying to talk down to you but I am not sure how basic you want me to get as far as explaining to hook up the ground on the meter or light?
__________________
Old 07-24-2009, 03:48 PM   #19
srasm950
I will try to get my hands on a voltmeter or test light and I think I can figure that out. Thanks
Old 07-24-2009, 05:58 PM   #20
ttocs
1994 Ford Mustang
ttocs's Avatar
all you need to do is hook up the ground on the meter or light, and start checking the wires in the harness on the amp. Turn the key on and just start checking one wire at a time.
__________________
01, 1994, 2005, 2008, coming, ford, mustang, no, premier, radio, sound, speaker, speakers, stopped, working
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
