Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-04-2009, 11:30 AM   #1
jfisch
Vehicle: 1998 ford mustang gt conv
Default HELP; MOTOROLA T605 INTO 98 WITH MACH460
Trying to put Moto T605 bluetooth kit into stock system. bought harness from install.com but plugs dont match up. Can't find plug and play harness to fit. any ideas?
jfisch is offline   Reply With Quote
Old 07-04-2009, 07:50 PM   #2
ttocs
1994 Ford Mustang
ttocs's Avatar
if you can get a pic of what you have(harnesses and such) I can probably get you through it.
__________________
http://www.cardomain.com/ride/2395420
ttocs is offline   Reply With Quote
Old 07-08-2009, 11:51 AM   #3
jfisch
Default pics of connectors
i have the am/fm/cass with separate cd below. i have the mach system so there are amps in the system with the connector behind radio on wall. I bought harness from install.com but connectors don't match up. no one seems to go back this far and peripheral elec says not compatible with fact amp units.
here are pics
http://mustangforums.com/forum/membe...onnectors.html
Old 07-08-2009, 01:07 PM   #4
ttocs
1994 Ford Mustang
ttocs's Avatar
this will be easy then. If you could find a link to the wiring schematic for that bluetooth kit I can get you through it. The pics you sent me had 3-4 hrns's in them, two small black square ones and two larger rectangular ones. Ignore the little ones and look closely at the larger rectangular hrns's. One will have 8 pins in it(and was probably plugged into another hrns, black I think), and one will have 5-7 pins in it. The black 8 pin harness(I point to it on page 2 of my cardomain page) is the speaker wires that go between the tweeters and the front amp. You can confirm this if you want to by turning the stereo on and then disconnecting that harness and the tweeters will go out. The tweeters are a standard 4 ohm impedence so the motorola unit should not have any problems playing though them. The bluetooth kits have a relay that will turn off the music to the speaker and then play the phone call through it so you can just use the front drivers side to make wiring easy. The only problem I see with this is that the stock stereo does not have a cell phone mute to quiet the stereo when you get a call, we might be able to wire another relay to turn off the sub amps to help.
__________________
bluetooth, harness, installation, kit, mach, motorola, mustang, pictures, relay, speaker, support, t605, tech, wire, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
