My OEM AUX Line In doesn't work... "No Aux Audio"
Old 11-14-2010, 03:59 PM
broda1115
broda1115's Avatar
I'm having a similar problem with my 07 GT but instead of saying "No Aux Audio" I don't even get the line in option it just cycles through all 3 of the Sat radio options. Any advice anyone has on how I can fix this I'd appreciate it.
broda1115 is offline
Old 11-15-2010, 08:09 AM
Wsone
Wsone's Avatar
Yep..same issue I had. I;m guessing your speed volume adjust and radio lights aren't working either. Apparently it is a somewhat common problem. Dealer said there was no fix that it was an internal error in the radio. They tried resetting it and "pushing" new software but that still didn't work. I found a guy here in the forum that had upgraded his Shaker head unit and bout it from him for a very reasonably price. Took about 30 minutes to install and everything works great. I can listen to my mpe or stream Pandora through the phone using the headphone jack.
Wsone is offline
Old 11-17-2010, 12:50 PM
broda1115
broda1115's Avatar
Any idea if the line in will still work if I buy a shaker headunit from an 06 GT? I only ask this because I know the 06's didnt have the line in option.
Old 11-26-2010, 11:23 PM
Wsone
Wsone's Avatar
Not sure. But I dont think so from other posts I have rad.
Wsone is offline
Old 08-02-2012, 07:17 AM
tutty
tutty's Avatar
can anyone tell me where i can find the AUX jack? i cannot find it...sorry for that, i might be "blonde" in this situation...
Thanks a lot
tutty is offline
Old 06-01-2013, 07:44 AM
rich74
rich74's Avatar
I have the same problem in my 07 gt, found out after a lot of research my bama tuner was to blame, it wiped out some of the programing for the radio, it will cost a 120 dollars to reprogram to radio at the dealership, but it will happen again when I switch between tunes from the bama tuner
rich74 is offline
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
winner99
10-01-2015 10:52 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: My OEM AUX Line In doesn't work... "No Aux Audio"
