Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-05-2009, 10:49 AM   #1
Graeli
Graeli's Avatar
Vehicle: 2007 Ford Mustang
Default ON/OFF Switch on Remote Wire?
I need an On/Off toggle switch for my system in my car because the amp and subs don't turn off when the car does so I was wondering if I could put the switch on the remote wire? Would that work or would it just cause more problems?
Thanks!
__________________
Bone Stock 2007 V6 Mustang
Coming Soon - 4.10 gears, CAI/Tuner Combo, and Flowmaster dual exhaust.
Graeli is offline   Reply With Quote
Old 08-05-2009, 01:08 PM   #2
JayMax03
2004 Ford Mustang
My Garage
JayMax03's Avatar
Vehicle: 2004, Ford, Mustang
do you have an aftermarket HU or factory?
__________________
2004 Smoked Gray Mustang "40th Anniversary"
Pioneer Premier Avic F90BT
(2) Cerwin Vega V-Max 12.2 subs
Cerwin Vega EXL1200D amp
Alpine MRP450 amp
Alpine 6.5 2-way coaxial speakers and component set speakers
Python 872 LE 2 Way Remote Start and Security
JayMax03 is offline   Reply With Quote
Old 08-05-2009, 06:48 PM   #3
ttocs
1994 Ford Mustang
ttocs's Avatar
yes, you could put a switch on the remote wire and as long as you remember to turn it off you will be ok. But it would be much much much easier to correct the problem and hook the remote wire up correctly.
__________________
http://www.cardomain.com/ride/2395420
ttocs is offline   Reply With Quote
Old 08-05-2009, 07:15 PM   #4
BlkVelvet
2000 Ford Mustang
BlkVelvet's Avatar
Vehicle: 2000 Ford Mustang V6 Convertible
Plus like in the olden days, you can get some nice Powerup thump. Modern amps have a staggered powerups to prevent the thump on turnon.
Look around for a power source that is powered buy the ignition switch. There are plenty of testers out there that are pretty cheap. Hook that up to the REMOTE lead, can be a low current source.
BlkVelvet is offline   Reply With Quote
Old 08-15-2009, 01:46 PM   #5
tator152
tator152's Avatar
Vehicle: 2002, Ford, Mustang GT
if your running an aftermarket headunit it should turn off. if you have factory i would say try to find an ignition wire or something to spice into. someone installed an remote wire on/off switch on my car before i got it and it is not cool
tator152 is offline   Reply With Quote
Old 08-21-2009, 12:48 PM   #6
CaptianMorgan65
CaptianMorgan65's Avatar
Vehicle: 2000,Ford,Mustang GT
It would work fine with the stock head unit. I had mine run like that for awhile, but I kept forgetting to turn it off. Also I didn’t want any switches or wires showing so i had the switch run under the cup holder and would pop it out to turn it off. I eventually ran it to the ignition. if you’re worried about having too much bass and not being able to turn it off, your stock head unit works pretty good for cutting the bass back down to normal.
__________________
2000 GT
K&N CAI
Flowmasters
SLP Lontubes
O/R X pipe
MGW Shifter
Predator tuner
BBK Springs
C&L Upper Plenum
CaptianMorgan65 is offline   Reply With Quote
Old 08-25-2009, 12:25 PM   #7
killbillet
2000 Ford Mustang
Vehicle: 2000 3.8
Send a message via AIM to killbillet Send a message via Yahoo to killbillet
I would just go with running it to the ignition wires, there is a wire that is 12v on on and start, im thinking that it was the white/pink wire on mine but im not sure
I needed it to hook up my ignition sence on my alarm, I just hate the look of switches and id prob forget to turn it off, lol
__________________
killbillet is offline   Reply With Quote
Old 08-31-2009, 04:31 PM   #8
Shadowc
Shadowc's Avatar
Vehicle: 2005 Ford Mustang
Send a message via AIM to Shadowc Send a message via MSN to Shadowc Send a message via Yahoo to Shadowc Send a message via Skype™ to Shadowc
Install a
Stinger Part # SGN21 * Amplifier "pop-Stopper"
Eliminates turn off and on pops
__________________
MAC Mustang GT Long Tube Header, Mid Pipe, & Exhaust
Alot of mods to come.
www.undergroundaudioandvideo.com
www.myspace.com/uavaudio
Shadowc is offline   Reply With Quote
Old 09-08-2009, 02:30 PM   #9
albertmathew40
Vehicle: Ford Mustang
putting lots of configuration can create problem. so you should be very careful before installing
__________________
Ford Mustang 2005 Wheel Mustang
albertmathew40 is offline   Reply With Quote
2006, audio, car, electronics, gt, hook, internet, mustang, remote, remotely, subs, switch, switched, toggle, turn, wire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
