Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-04-2009, 06:48 PM   #1
Red ll iine GT
Vehicle: 05 Mustang GT
Default Wiring problem on sub..help
So I hooked everything up..got it playing..and went to go inside..and the sub comes on..i open the car thinking that i mightve left something on..when i open the door..it goes off..so i close the door and wait for a sec..then it comes back on..any ideas?
__________________
Quote:
Originally Posted by S197winstang View Post
What is a brenspeed?
Quote:
Originally Posted by KTownGT View Post
I... I'm not 100%, but, I believe it is a small boat that was used in the colonial times...
Hmmm
Red ll iine GT is online now   Reply With Quote
Old 10-04-2009, 06:52 PM   #2
HypromanGT
Vehicle: 2008 Mustang GT
My first guess is that you've tapped into an "interesting" source for your remote wire; one that is hot more often than you want. What did you hook the remote wire to exactly?
Also how do you know the "sub" is on (I assume you mean the amp)? Does it pop? The radio must not be on, right?
__________________
-- 2008 Alloy Metallic Mustang GT Premium --
Ford replaced: 2006 Tungsten Grey Mustang GT Premium (Water Leak Edition)
HypromanGT is offline   Reply With Quote
Old 10-04-2009, 08:30 PM   #3
Red ll iine GT
By "sub" i meen subwoofer..which is powered by the amp so I guess yes the amp..I used the Green Battery Wire in the Pin 13 Location of the shaker power. It doesnt pop..the sub just bumps really loud and doesnt stop until i do something (turn key..open door..close door etc.) I think its where the shaker has a constant power source..what are you all using for your power wire to slpice?
__________________
Hmmm
Old 10-05-2009, 10:43 AM   #4
HypromanGT
Pin 13 of which plug? Check out this diagram: ftp://hyproman.serveftp.net/2005_mus...dio_wiring.pdf
It looks like either way it's incorrect. Pin 13 on the large plug is "POWER GROUND", and on the smaller plug it's "MONO SHIELD". Unfortunately there are no wire colors on this diagram.
__________________
Old 10-05-2009, 03:00 PM   #5
Red ll iine GT
My bad..Pin 1 Battery..wat did you all use?
__________________
Hmmm
Old 10-06-2009, 10:10 AM   #6
HypromanGT
Quote:
I *think* I used pin 2 (RUN/ACCESS), but I can't honestly remember. I think pin 1 is on all the time. You are probably hearing the sub "jump" when the radio comes on. Check the amp to see if it is on (ie: LED indicator) when the car is completely off. I bet it is on all the time. I would disconnect the amp until you get it sorted out, unless you like dead batteries...
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
