Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 11:32 PM   #11
audiofrek19
Vehicle: 1997 Ford Mustang
so yea whats the story with integrating the amps in those. i have heard ppl just turn the amps on and everything peachy keen but i have never had that luck
audiofrek19 is offline   Reply With Quote
Old 11-04-2009, 08:24 AM   #12
ttocs
1994 Ford Mustang
ttocs's Avatar
ford used a high voltage input, and a strange impedence on the subs so if they are not installed right it will make the amp angry.
With a little tweeking, the mach system will sound much better then with the stock deck
__________________
http://www.cardomain.com/ride/2395420
ttocs is offline   Reply With Quote
Old 11-04-2009, 11:23 AM   #13
xkape
Vehicle: 2002 Ford Mustang GT
Even though water ****ed my amps up (leak in roof, don't ask). I installed an Alpine HU and it sounded waaaay better than the stock HU. All I did was go to Best Buy and buy a Mach 460 wire harness. Take out the old HU, wire everything up and solder it and presto.. 30 minutes start to finish. Oh, also, my HU was a single deck so I did have to buy the faceplate thing. Something to note. Since that area is pretty much barren (empty), make sure the HU you buy has the ability to screw that little plastic piece into the back. It goes on a little slide rail on the faceplate piece so that the back of your HU is supported and doesn't lean backwards and jiggle around.
xkape is offline   Reply With Quote
02, 06, 2002, deck, ford, forum, gt, hd942u, head, install, kdc, mustang, problem, replace, unit
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
