Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-04-2009, 08:37 PM   #1
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
Vehicle: 2007 Mustang GT Coupe
Default S197 ac dash panel replacement HELP
I feel like I'm goin crazy. removed my burnt alpine ida-x001 last weekend and replaced with the new ida-x305 tonight but cannot locate that big power connector for the ac/dash panel. it took me a bit to remove and I'm not sure if I pushed it out of the way somewhere but cannot locate it to reconnect!! check the pics and if you know what I'm missing let me know please. this is why you shouldn't disconnect things and 3 days later try to reconnect haha. Its the big power connector in the lower of bottom pic.
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
Rubrignitz is offline   Reply With Quote
Old 11-04-2009, 09:35 PM   #2
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
since its now 8:30cst I'm going to ride around another day and try to locate this connector out in the sunshine and with two other (IT specialist) coworkers. I feel stupid I can't find this gd connector to button everything back up tonight but then again..I searched for 5 mins then posted here. I must have pushed that thing out of the way somewhere.
If anyone has a pic showing it being removed from the panel I could trace it.....
EDIT: FOUND IT!! I pushed that sucker so far up under the dash out of way it took an LCD panel light to locate it. doesn't help that I have to do everything in the pitch dark garage cause I work 60 f-in hours/week...
I'm now laying more dynamat on my shifter tunnel...amazing how much drivetrain sound emanates from that tunnel...my car should be much quieter..and audio much cleaner with the extra dynamat.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
