Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-26-2005, 06:17 PM   #1
pmadren
Default 2005 Mustang GT VSS Wiring Question
Can someone please tell me, what color and where I can find the VSS wire for a Radio that has a Navagation system? Also looking for wire color for Back up lights also.
I have checked several sites and have some wire colors but when I goto the PCM area there are other wires that are close to the colors on different plugs.
THANKS A BUNCH
__________________
05 Mustang GT: SC Yellow,Dark Char Leather,Carbon Vinyl Inserts, Yel Stripe (MACH1 design),MDM Head Rest Wrap "GT" ,Door panel inserts dyed to match stripe, Auto tran,Saleen SC W/C&L CAI,39lb inj.3.6 pully, 441RWHP 432 Torq----Owner of GrandDesignMat.com
pmadren is offline   Reply With Quote
Old 08-06-2005, 11:54 PM   #2
tboucher
Send a message via ICQ to tboucher Send a message via AIM to tboucher Send a message via Yahoo to tboucher
Default RE: 2005 Mustang GT VSS Wiring Question
I could use this info as well, trying to install a nav system.
__________________
2005 V6 Legend Lime Green Convertible
tboucher is offline   Reply With Quote
Old 08-08-2005, 12:12 PM   #3
pmadren
I went to a place called www.rostra.com. I bought this magnet kit that goes on the drive shaft and the pluse counter counts the rotation of the shaft. It cost me about 50.00 for the kit. IT WORKS GREAT
__________________
Old 08-08-2005, 08:54 PM   #4
sick95gt
You can almost always get it behind the gauge cluster. You'll have to have a digital multimeter to test for it while the car is moving. You can also call Pioneer tech support and say that you have an AVIC-N2 and you need this info and they might know where to find it for your vehicle.
__________________
95 gt vert 5spd- Edelbrock RPMII manifold, performer heads, ed curtis cam, 1.6 rr, 24# inj., 76mm c&l maf and tru flow pipe, 70mm tb, bbk headers, bassani x-pipe w/cats, mac 2.5 catback, MSD 6al ignition dist/cap/rotor, 4.10's, FRPP aluminum driveshaft..
sick95gt is offline   Reply With Quote
Old 08-09-2005, 02:37 AM   #5
hawgman
I ♥ Acer
Send a message via Yahoo to hawgman
If you are looking at the PCM from the front of the car, remove the cap on the top plug. You want the blue wire with the yellow tracer. It is on the left side of the top plug in the third space from the bottom.
Technically it is no longer VSS because the PCM reads the OSS and makes up its own VSS inside of the PCM, so its electronic. You can read it with a scan tool and bring up the VSS pid. Tap in to this wire for your "VSS" signal for navigation systems. (thanks Casper )
[IMG]local://upfiles/13513/86D850258C874E6EAD607E6F2D9D62A6.jpg[/IMG]
As for the backup lights, just tap in to a +voltage wire to a backup light in the trunk.
hawgman is offline   Reply With Quote
05, 06, 2005, ford, light, locating, mustang, pcm, radio, reverse, sense, speed, test, vss, wire, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
