door lock/unlock issue
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Having a hard time determining whether or not I need some sort of bypass module on my 2006 w/viper 5902. The doors currently do not lock/unlock.
no module you might need a relay pack part number 451m
and use this schematic
http://www.commandocaralarms.com/positivepulselocks.asp
I got it to work, but now since I'm using the dome light supervision, it thinks the doors are open until the light goes off. What do I do?
where did you get the door triger from ? the door pin ?
you have to go to the top of the fuse box there is a plug there the wire is black/white negative , or you can run the cable to the courtesy light
for the domelight supervision you can add a diode so it don't send the signal to the door triger if they are on the same wire
LivingInThePast
09-16-2015 12:20 PM
