Pioneer AVH-P4200DVD Install Questions
Old 08-23-2010, 12:09 PM
aquajr
aquajr's Avatar
Default Pioneer AVH-P4200DVD Install Questions
So I picked up this unit and plan on doing the install myself with the help of a buddy. I have been searching around the forum trying to figure out exactly what I need and things to watch out for. I want to be able to use all the features of the unit. It is going into an 06 GT with the Shaker 500 system.
As far as I can tell I will need the following:
5V regulator
Wiring Harness Metra Part # 70-5521
Dash Kit
Is this basically it aside from tools, etc.?
I was thinking I would route a USB cable into my center console so I can use a flash drive for music and do the same for an Ipod. How long of a cable would I need?
Is there anything to watch out for (easy to forget/mess up)?
aquajr is offline
Old 08-23-2010, 12:44 PM
Pony123
Pony123's Avatar
You would have to get the cables from Pioneer.
Pioneer sells the ipod cable sold seperatly. I dont think you need th 5v regulator but it wont hurt..
let me know if you need help on taking the stock radio out.
Pony123 is offline
Old 08-23-2010, 01:04 PM
aquajr
aquajr's Avatar
Do I also need an antenna adapter?
aquajr is offline
Old 08-23-2010, 03:26 PM
2007bluestang
2007bluestang's Avatar
ya you need an antenna adapter, and the cable disables your aux plug btw. but i had mine wired to the center console..but ya you need the antenna
2007bluestang is offline
Old 08-23-2010, 07:06 PM
allinon72
allinon72's Avatar
I just installed the 4200. See my thread:
https://mustangforums.com/forum/2005-2011-mustangs/613521-pics-of-my-double-din-install.html?highlight=double+din
You need a wiring harness, dash kit, 5v regulator, and a 12v relay if you want to do the parking brake bypass. You do not need an antenna adapter.
allinon72 is offline
Old 08-23-2010, 07:08 PM
allinon72
allinon72's Avatar
And you don't need the Pioneer iPod cable. Your regular white cable that came with your iPod will plug into the USB port and work just fine. However, if you want to watch videos from your iPod, you need the iu200v iPod cable from Pioneer.
Old 08-23-2010, 10:44 PM
aquajr
aquajr's Avatar
That looks sick, can't wait to get mine in. How long did the install take you?
I got the same deal from Amazon, pretty smoking.
aquajr is offline
Old 08-24-2010, 10:48 AM
Pony123
Pony123's Avatar
An antenna adaptor is only needed i fu have a V6 with the Shaker 500
Pony123 is offline
Old 08-24-2010, 10:37 PM
allinon72
allinon72's Avatar
I took my time making the harness, probably took me 2 hours or so. Took me less than an 45 minutes to put it in the car since I know my way around the dash.
Old 08-25-2010, 09:14 AM
allinon72
allinon72's Avatar
Originally Posted by chennaiescorts
I read this post. Its very informative and interesting also.
chennai escorts, chennai female escorts,
bangalore escorts, bangalore female escorts
At least attempt to mask the link titles. Jesus these spammers are dumb
Quick Reply: Pioneer AVH-P4200DVD Install Questions
