Install aftermarket radio...but have CanBus turn-on power...help
My 08 Expy, and my 09 Mustang are wired so the CanBus supplies activation power to the radio via the Inst. Cluster.
This causes a problem when you put an aftermarket radio in. There are no easily accessible "Key On" hot wires to be found. The closest I can find is at the fuse box itself.
I just want my headunit to operate like the factory radio did. Come on when the key is in "ON" or "Accessory", and keep playing until the door is opened.
I found this...but at $100...there has to be an easier, aka CHEAPER method.Thanks guys. I am pulling my JVC AVX820 in the Expy to put into my Mustang and installing a Kenwood DDX616 in the Expy. Figure I'd try to wire them a little better this time around.
you can wire the red acc wire from the headunit to the passenger side fuse box and one of the unused fuse spots turns on in acc posistion and doesn't shut off until you open the doors when you shut the car off. i dont remember which fuse number but i can check tomorrow. you can buy an add a circuit from autozone and put it in the empy fuse holder and hook the red wire to that.
the trigger line doesn't provide any load. it just serves as a On/OFF switch...basically Key On/ACC/Off.
the main wiring harness in the dash still has the normal power wire that is used for the OEM radio.
I ended up getting the PAC adapter from another member here on MF for my Expy last night for $35 shipped...but I am still looking for a cheap way to do this on the mustang.
you are incorrect.The red acc wire does have a certain amount of current it draws.Each radio is different, say a single DIN headunit as opposed to a double din with a screen.
yes, it draws an insignificant amount of current. so little, that a simple 5 amp fuse would be more than sufficient to protect.
I think I might tap off the power window circuit. that is only powered when the key is on/acc and they are on the 10 minute circuit as well. I think their fuse could easily handle the tiny load the trigger wire would use.
