base v6 s197 sub and amp help needed!!!
Hey guys I was wondering if you could give me directions and tell me what all i would need to wire a 10" sub and amp into the factory head unit? I've installed stereos before just never integrated into the factory set up...
if the amp has high level inputs you can tap off the rear speakers and run the wires into the amp. if your amp doesn't have high level inputs you need the line out converter(loc). you tap off the rear speakers into the loc and then run the rca to the amp. get power, ground, and turn on to the amp. you can buy a loc at must audio stores or online.
Since you are just wanting to tap into your factory setup for a sub, you can go with something like this: http://www.sonicelectronix.com/item_...AC+SNI-35.html
I'd cheat and tap the LOC into the rear deck speakers.
mungodrums
10-07-2015 04:01 AM
mrappe
09-26-2015 10:16 AM
