Shaker 500 Remote wire?Help Please!
Hey guys!so I took everything off my car including the shaker 500,and everything on the dash and I cant figure out where the remote wire is?Is there even one on the shakers?If they don't,how do I make it to power the amp on?I have heard about hooking it up to the ignition but how do i do it?
Btw i drive a 2007 Mustang GT
Thanks
David
Thanks
David
The way I did it was I hooked the REM to the Gray/Yellow under the passenger dash. In the clump of wires going to towards the stereo. That is the ignition wire. I installed competition subs and a 1600 watt amp without ever touching the Shaker in the dash.
You will need a Line Out Converter. This will convert the factory speaker level outputs to RCA preouts so you can use an aftermarket amplifier. It simply taps into the existing factory speaker wires without disconnecting the factory speakers so they will still work.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
