2011 GT/CS Shaker 500: Adding OEM Nav?
Hi all,
I've got a 2011 GT/CS with the Shaker 500 w/ Sync. Looking at options for stereo upgrades, and after playing around with the OEM Navigation setup, I regret not opting to get it. I was considering installing my old deck from my trade in a Kenwood DNX7140 DD unit with the metra kit, but would prefer to have OEM if possible...
Anyone know if cars built with just the Shaker 500 could be upgraded to the OEM Navigation? Seeing that the NAV unit seems to use the same system. I looked online, and saw that the parts relating to the NAV unit and looks somewhat feasible. The only issue I see is the wire harness not being compatible.
I don't know what the price would be for just the navigation. But one dealer I spoke with said it's "possible", but has never been done before.
Assuming the price isn't outlandish for the parts and installation, is it even possible?
Thanks in advance!
Thanks in advance!
Just curious has it been confirmed that the wire harness is different? (Not suggesting I don't believe you.) Prior to asking on the boards I've been given contradicting answers (from dealers and various sources) without being able to confirm with certainty that it is different or not.
Figure this question may come up again and would help answer questions for other who may do a search on it.
Regards,
i am also interested in adding factory navigation to a 2011 mustang gt w/ shaker 500. can someone explain why this is currently not possible? would it be possible to add the factory nav using harness adapters or by splicing into the existing factory wiring harness?
Fordparts.com has some information about the different pieces between the two setups, but I couldn't find any wire harness information anywhere. I'd be curious to see what exactly are the differences and the actual feasibility to swap/upgrade.
While I'd love to upgrade mine to the OEM nav and auto climate control, at this point in time the ends doesn't seem to justify the means. One promising thing on the flip side, the metra kit and scosche kits look pretty good so far.
Either way in both scenarios, IMHO we'll have a easier time to figure out what's the best route to go as either one becomes more readily available. We just need to be patient for the time being which is the toughest part (for me anyways).
Regards,
See here, pages 8-13 specifically. All information about your car (2011) is here.
Regards,
