Add woofer in a door on a 2005 Deluxe Mustang
Hi!
I have a 2005 convertible mustang. I change the stock radio unit with a shaker 500. Now I want to install a woofer in the door. I have bought 2 impact woofer, and 2 audiobahn crossover. But my mustang is a deluxe, and it haven't any woofer in the door. How can I mount them?
Thanks!!
Thanks!!
Buy door panel replacements that have the shaker 500/1000 sub-woofer cut-outs already done, or fabricate/cut-out your own opening on your existing panels. This as an example. You´d have to find a place that will ship to Italy, or have a friend in the states here that will re-ship for you.
You don´t mention the size, or depth of the subs/woofers, so unless they´re specifically sized 8´ ones, they´re not going to fit. Then of course you´d have to run wiring.
Thanks Wayne!!
The diameter of woofer is 6,2 inch. I think to use the oem wiring and split it with a crossover; low singal to woofer, high to oem speaker. Is it right?
Unfortunately in Italy there aren't many doors Mustang,and if I buy one in the usa spends a lot of shipments!
But simply cut the door or do I build a box for the woofers like the originals?
This will require some though on your part, as well as some decent fabrication skills. Not super-difficult, but still.. My advise would be to take it to a shop with some specialization in this if you've not attempted something like this in the past.
'stangdude
08-12-2015 01:27 PM
