Need a little info on (touch screen) head units
#21
It simplifies the install. Gives:
- VSS(Vehicle Speed Sensor) for GPS, so you can still get a decent guestimation of where you are when the GPS signal might crap out. And other unit speed display purposes.
- 5v remote turn ons for the factory amplifiers(faker 500/1000 systems), so you don't have to step it down yourself with a resistor or 5v regulator.
- E-brake sensor, saves you from running a line from the e-brake for this (assuming you weren't going to bypass it to start with).
- 12v delayed accessory line on from can-bus, as many later models don't have the actual 12v line run to the harness. The factory head-unit gets turned on by the can-bus signal instead.
- Reverse sensor, to switch to a reverse camera if hooked up without having to tap additional wiring.
#22
I like the touch screen alot. I wouldn't say its iphone quality, but its good. I don't have any troubles with it, and having physical buttons for your most used buttons is nice too.
#23
No edit button on phone. I really like vminnovations. I have only had to deal with their customer service once, and that was because they called me to let me know an amp I ordered was out of stock. they seem to have lower prices than crutchfield and sonicelectronix
#24
None of 'em that I know of use screens like the better androids and iPhones. All resistive touch-screens, not capacitive like the aforementioned. Expensive as hell for that size without a major level of mass production.
#25
I'm in Fort Wayne, but I go down to carmel for long weekends so whichever city has a better shop nearby will probably be where I go. And thanks for the offer but I think I'm just way too far from Evansville lol, but I still really appreciate the offer man thanks!
By the way, do you by any chance know of some good shops for the work near there? I would also be willing to drive down or up a little farther if necessary to get to said shops. Thanks again guys!
We are the toe-fungus of the state.
#26
Need. No. Want, should, yes.
for another $70-$120 ill live without that one. but thank you for clarifying. that almost should be stickied.
#27
Aye, but you likely already have it run to your radio harness, think this (can-bus activated with SJB 12v delayed accessory line not run to radio harness) didn't start until the 08's. So you didn't have a shaker system originally?
#28
Also, I was hoping to get your input in this thread! Do you think going with a touch aftermarket is worth the trouble/cost? I'm not really an audiophile, but was looking to spruce the interior and people really vouch for this units reliability so I thought I'd take the leap- nothing wrong with my shaker though.
Do you have any recommendations for touch head units?
#29
Basically just some simple audio stuff from a reputable shop so I can get a warranty (peace of mind). Thanks man, I appreciate the help!
Lol, if you're the toe fungus then I guess Ft. W is the dandruff on the hair? haha.
#30
That is good, I was just worried about a low quality screen bothering me or something. Yeah I wanted to upgrade to the larger head unit but then I lose all buttons lol.
