Help. Getting alternator buzz?
Old 10-01-2011, 02:49 PM
cMaikai
cMaikai's Avatar
Default Help. Getting alternator buzz?
Car is 2004 3.9 Mustang w/ Mach 460 system.
I had an aftermarket radio put in in 2007. All other stuff is stock/Mach 460.
My knowledge of car electronics is limited to none so bear with me.
Recently, I started to hear an buzz coming from my rear speakers that changes pitch with the engine revs. I went behind the radio to see if I could figure it out. I could wiggle one of the RCA cables and the buzz would stop, but it would eventually come back. No idea.
I've read there could be a loose ground? I've checked my voltage with a meter and voltage is fine. 12v off, 14.4v idle.
I had an audio guy tell me it's the amplifier, but I don't want to spend money replacing it without being sure.
Just trying to figure out what's up and what needs to be replaced.
Thanks!
cMaikai is offline
Old 10-01-2011, 05:39 PM
Blueper
Blueper's Avatar
Go and get your battery checked.
Blueper is offline
Old 10-02-2011, 12:23 PM
cMaikai
cMaikai's Avatar
I just replaced my battery because it was spilling acid.
cMaikai is offline
Old 10-03-2011, 09:10 AM
AudioNutz
AudioNutz's Avatar
Re-ground everything, and ground it to the same point on the vehicle's chassis.
AudioNutz is offline
Old 10-03-2011, 10:11 AM
cMaikai
cMaikai's Avatar
Where can I find all of the grounds?
cMaikai is offline
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
NYstang
09-30-2015 09:56 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Help. Getting alternator buzz?
