2004 mach 460 replacement door speakers - MustangForums.com
Old 01-04-2012, 09:39 PM   #1
hole18n1
Default 2004 mach 460 replacement door speakers
well took off door panel today and thought my speaker was just rattling and nope found out its blown. Its not always bad just when i turn it up the base makes them rattle or sound like ****. I only have the base set in the middle its not even way up. My system is stock 460 so was wondering if i should just throw a factory replacemnt on back in or what a good replacement would be and just yank the two front ones and throw some new better ones in?
Thanks
hole18n1 is offline   Reply With Quote
Old 01-10-2012, 04:14 PM   #2
ttocs
ttocs's Avatar
never found a good replacement for it because it is an 8 ohm 5 x 7 woofer. Closest I think I ever heard was a dual 4 ohm 6.5 version that could fit but its been a while. If you have replaced the deck, you can bypass the stock amps and just put a fullrange speaker there and run it off the deck power no problem.
ttocs is offline   Reply With Quote
Old 01-25-2012, 09:25 AM   #3
MustangHEMIguy
Samething happened to me. Went with Alpine Type-R to keep up with wattage (around 100watts/rms). Year later ended up gutting the entire sound system. Just a heads up, you will LOSE a lot of low end sound, but gain mid-range detail... It's a 'some hate it or some love it' scenario
MustangHEMIguy is offline   Reply With Quote
2003 Mustang Mach 1 AUTOMATIC!!!! dubarado Mustangs For Sale 6 12-23-2015 02:16 PM
2002 Mustang GT Premium 5 Speed JonnyBlazeGT Mustangs For Sale 3 11-03-2015 02:10 AM
Win a $1500 AM Parts Overhaul - AmericanMuscle AMAlexLazarus AmericanMuscle.com 18 09-29-2015 02:35 PM
Hydro dipped carbon fiber Fuel Door SYNY5TER Parts For Sale 0 09-02-2015 02:35 AM
Speaker Question 69FB Audio/Visual Electronics 2 08-18-2015 09:50 PM
2004, 460, audio, auio, blown, door, factory, ford, good, gt, mach, mustang, replacement, speaker, speakers
