Scosche DD Kit & Wiring Kit Questions
Hi All,
Surfing on ebay, I found a Scosche kit available that I was able to bid and win on.
Weird how Scosche's website still lists them as being unavailable/out of stock but there are kits floating around online. I guess they're still fixing the bugs.
Anywho... My car is a 2011 GT/CS w/ the Shaker 500 audio package.
I have a Kenwood DNX7140 from my old car that has been sitting in a box since I got the Stang. I'm looking to install the Kenwood and utilize the OEM speakers/Shaker 500 (for now... Until I can figure out what I want to piece together.) However, I also want to retain Sync functionality as well as the steering wheel controls. I've read up on other folks builds but am a little confused as to what I need specifically to accomplish the above.
From what I read I would need:
- Scosche FDSR - 2005 - Up Select Ford CAN Bus Interface
or
- PAC MS-FDR1
- PAC SWI Jack (Kenwood Adapter)
- Scosche CRAB Attenna adapter (?)
Based on the wording of the Scosche description it does not come with the module needed for stereo controls on the steering wheel.
Looking to get feedback from the community on experiences between the FDSR vs MS-FDR1, as well as ensure I've got the right parts list to get my Kenwood setup.
Any feedback/comments/suggestions would be greatly appreciated!
Regards,
or
- PAC MS-FDR1
Regards,
I would go with the PAC MS-FDR1 for the sync. But if you have a good headunit with Nav/Bluetooth, I wouldn't worry about sync. Also replace the 4 6x8 speakers. You will love the sound.
I would also get the firmware update before i would start the install. Alot of people have had issues with the unit draining the battery.
I've got a sort of old Kenwood that featured the Garmin Navigation integration initially. It's the DNX7140 unit. While sync has several faults, I do like the microphone setup for hands free much better than the way the Kenwood handled it. And admittedly I do like some of the services that are available.
I have bits and pieces of audio equipment from my old car that I'll end up reusing, but still deciding on what to select for speakers and what not. I'm also doing some interior updates/refreshes and want to try to avoid having to pull panels off several times.
A hint of what I'm working on...
I'm kind of surprised there aren't any documented scosche installs on our board already.
Last edited by Maverick302; 03-24-2012 at 02:24 PM. Reason: Typos and punctutation errors.
Hey Mondo,
What antenna adapter did you use for your HU? I'm getting ready to place an order for the PAC stuff from Crutchfield, and figured I'd buy everything from one place. They have two antenna adapters listed that would work, one with the motorola male end and another with the female end. I'm assuming I need the male end.
http://www.crutchfield.com/p_12040CR...a-Adapter.html
Regards,
Regards,
The trim is called "Di Noc" made by 3M, and bought it from http://www.carbonfiberfilm.com. Application seems daunting, but it's not as bad as it seems. A quick search on Youtube, and you can see how easy it is to work with. I'm planning on starting another thread when I get all the pieces completed.
Regards,
