Hardwiring Detector Question
Old 05-28-2012, 03:59 PM
wayne613
wayne613's Avatar
Originally Posted by silverstang23
This will be in my 08. So it is better to tap a fuse then to tap a wire
The "worry" is about the SJB, as it is not designed to handle any true additional significant load. In our cars, all but the ignition wire are running directly off the SJB anyhow, accessory delay lines all run back to it. The circuit I gave has multiple higher draw lines on that same circuit, so you should be fine with just a small additional draw.
His other concern was that you would use actual fuse taps, rather than the "add a fuse". I have yet to see anyone try to use the bladed true fuse taps outside of a shop, but just in case..
i.e. use this(but the mini rather than ATC version):
That will be available at any autoparts store.
wayne613 is offline
Old 05-22-2015, 10:17 AM
SYMBOLISM
SYMBOLISM's Avatar
I have read so many of these on hard wiring RD sorry if this has already been covered.
Would it be ok to splice the power into the remote wire behind my aftermarket deck (with an inline fuse) and then ground the ground to something.
SYMBOLISM is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Hardwiring Detector Question
