14 Shaker Audio Replacement help
Hello Folks,
New to the community but a long time Mustang enthusiast, just picked up an early birthday present (2014 Mustang GT Convertible) and I am seriously disappointed in the shaker audio system, it’s a joke! I haven’t done a car stereo since I was a teenager (long time ago)... I like clean clear systems with punchy bass, what do you all recommend? I was thinking Component up front, 6x8 in the rear, and a 12” JL in the back. I have no idea on amps, last time I did this Phoenix Gold was the good stuff.
Thanks all!
Thanks all!
Hello Folks,
Thanks all!
Thanks all!
That is what I have, component in front, coax 5x7 in the rear deck, and a 12" jl in the back. I have JL amps powering everything. they are both 360 watt RMS, one is a 2 channel and the other is a 4. the 2 channel is powering the sub. I have the amps on a shelf in the trunk under the speaker deck.
feel free to ask any questions if you have them.
I have an install thread on a head unit, I kept all the steering wheel controls, and you need to make sure the hu has sat radio if you want it, you need a special adapter for the sync to work right, and it might require some setup, but I haven't done it with sync so I don't know.
I assume you want to do it yourself, which is what I did, but I would recommend getting friendly with a local car audio shop to either buy the stuff from(easier warranty coverage), or to at least ask questions from if you get stuck or need help programming the sync.
