Hi-low adapter/ speaker-line level converter HELP
Old 12-27-2014, 02:55 PM
Chromeshadow
Chromeshadow's Avatar
What did you hook the RCAs to? Do the lights on thr amp light up?
Chromeshadow is offline
Old 12-28-2014, 09:12 AM
gtjason
gtjason's Avatar
RCA's are from "SW" RCA terminals on the back of the radio. There are front,rear, & SW. IT is from SW to the RCA ports on the amp. Yes it lights up. My meter shows power in but not out. Like there's no signal from the RCA. would a bad ground do this too, or would it not power up at all?? I have the ground ran to 1 of the tail light studs where it comes through the body. (smashed to the body) Should i bare the metal? i assume it wouldn't work if it wasn't grounding.
gtjason is offline
Old 12-28-2014, 11:33 AM
Chromeshadow
If both the head and the amp light up, they are getting power. The amp may have a blue wire that tells it the radio (head) is on, this needs to go to 12V or 6V that comes from the head. The amp instructions will tell you the voltage the blue wire needs.
I'm just wondering if i need this "line level converter" on my 01 gt. I have a Kenwood deck & I just added 2 subs & a new amp.
no, hooking to the RCAs of your new head will work fine.
Here is what I would do, hook a speaker to one of the speaker outputs of the head unit to make sure it's working.
Play music with your phone or Ipod into a mini to RCA cable into the AMP RCA inputs to check the amp.
This will let you know which is not working, the head or the amp.
Old 01-04-2015, 12:42 PM
gtjason
gtjason's Avatar
I tried the ipod to amp RCA's. It worked that way. There is 12v on the blue wire at the radio to ground & at the amp to ground. I bared the metal around the taillight stud where I had the ground. It gave me a + reading this time when i ran my meter from blue wire on amp, to ground.Where before it read -. However the 4amp power wire still reads -12v when I run the meter from power to ground.But power light is lit up.All speakers work in the car except the subs so I'm leaning toward the RCA outputs on the radio. But the radio is only a yr old. could there be a wire I need to disconnect on the Scosche wiring harness that may be diverting power from the RCA's?? As my luck runs, the book for the radio is now missing from my car!!!
gtjason is offline
Old 01-04-2015, 05:45 PM
Chromeshadow
If the amp/subs work when you hook up your ipod, the prob is either the RCA cables from the head or no sound from the head RCAs. Some heads have an off/on menu for the subs. You should be able to get the manual for the head on line.
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Hi-low adapter/ speaker-line level converter HELP
