Changing radios
Old 01-19-2014, 11:07 AM
jbish33
jbish33's Avatar
Default Changing radios
I have a 96 mustang, and i got a new radio as a gift. I got it all hooked up and wired but then didnt turn on, i put the old one in and that didnt work either. i then noticed other functions of the car werent working which concluded it was a fuse that was the problem. i found the blown fuse and replaced it. after replacing the fuse the old radio and everyting worked again so i tried the new one and the fuse was blown again. both radios are JVC, one is model kd s 570 and the new one is model kd r330. i looked at the specs and both 12 v and only difference is the power output, the new one outputs 10 watts more and 4 watts of continous power. If anyone could help me get the new radio in and what could be causing the blown fuse? I wouldnt think the power output would cause this to happen with a difference that small is that the problem?
jbish33 is offline
Old 01-19-2014, 11:45 AM
clucas
clucas's Avatar
Do all of the wires in the old plug match up to the wires of the new plug? I'm not sure if JVC has changed their plugs/wire locations on the newer models, but that is the first thing i would look at. You may be plugging in the new radio and it could be trying to draw current from a wires that doesn't do that. If the wiring is the same, then you may have a bad radio.
clucas is offline
Old 01-20-2014, 01:17 PM
jbish33
jbish33's Avatar
Thank you, there was two wires that i connected that werent connected on the previous, i connected all but those two new ones and it worked perfectly after going through a cpl fuses.
jbish33 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
vbonina
09-22-2015 08:31 AM
Gkid182
09-22-2015 08:17 AM
unit91
09-15-2015 09:53 AM
Quick Reply: Changing radios
