Where to connect the ground wire for an amp in the rear.
Old 06-07-2014, 08:50 AM
KevStangZona
KevStangZona's Avatar
Default Where to connect the ground wire for an amp in the rear.
I have everything apart now and I am looking for a place to ground my amplifier in the rear.
KevStangZona is offline
Old 06-07-2014, 08:57 AM
cruisin5268d
cruisin5268d's Avatar
You see all that bare metal? There you go. Look for an existing grounding screw our use a self tapping sheet metal screw and a lock washer
cruisin5268d is offline
Old 06-07-2014, 02:17 PM
dj2014
dj2014's Avatar
Bare metal? I see lots of painted metal.
dj2014 is offline
Old 06-07-2014, 09:58 PM
cruisin5268d
If you stick a sheet metal screw in it you'll have a solid ground.
Old 06-12-2014, 02:26 AM
ticopowell
ticopowell's Avatar
I tried a few different screw locations in my last mustang but got some alternator whine with most all of them... but some of that is directly tied to the headlights as well. I eventually ended up using the seat belt bolt as a ground... Couldn't find anywhere else that I liked. I don't think I would recommend that again though... probably wasn't the smartest idea I have had.
ticopowell is offline
Old 06-12-2014, 10:21 AM
KevStangZona
Thanks I ended up loosing a bolt that holds the seat in and connected it there. No alternator whine.
Old 06-14-2014, 11:31 PM
cruisin5268d
Good idea. Some of those bolts are a bit big for a ring terminal to fit over. Glad it worked out for you.
Old 01-23-2015, 08:36 AM
BlackPony14
BlackPony14's Avatar
Kev - Where precisely did you find the bolt you're speaking of? Everything I can find under the rear seat is painted except the bolts connecting the loop bar for the child seat to the frame. Unfortunately the bar between the two bolts is painted. I'm hoping your location provides an easier connection.
Thanks!
BlackPony14 is offline
Old 01-23-2015, 01:17 PM
ticopowell
ticopowell's Avatar
I used the upper bolt from the seatbelts on my last car, This one i found a stud in the spare tire well that has worked great. If you want to use a seat bolt that works as well, but to get to it you need to unbolt the seats.
Old 01-23-2015, 04:04 PM
Chromeshadow
Chromeshadow's Avatar
I ran a wire back to the negative side of the battery...same gauge as the positive wire.
Chromeshadow is offline
Quick Reply: Where to connect the ground wire for an amp in the rear.
