03 conv v6 mach sound, indash 6-disc, parasitic drain
Hey guys newbie here first post! Been trolling around but I'm stumped.
checked my system and it has a drain of 9.9 amps. Found source to be FUSE 9 ,(rear stereo amplifiers). Checked amp's when disconnecting both amplifiers and amp shot up to like 19.00 amps. Can someone point me in the right direction. Thanks!
First thought would be a bad amp, if the speakers work without it plugged in just leave it unplugged and the drain should be gone.
If not then you will have to get a new amp to use your back speakers. most people don't notice back speakers since they are mostly just filler sound, but if you want them you could always go aftermarket and get a new amp and speakers.
Interesting enough it's fuse nine for the rear and front amplifiers. It was pulling about 19 A even if I disconnected the rear subs it was sucking the same of April it would actually go up I know there's a front amp what does that power does anybody know what the front amp powers??
fordluver
12-01-2006 10:27 AM
