Shelby Kicker Door Sub Wiring question
Old 07-25-2014, 10:51 PM
cruisin5268d
cruisin5268d's Avatar
Originally Posted by jz78817
ok then.
oh, BTW:
this is the same kind of mindset which convinces people they need to spend $1,000 on a 6 foot speaker cable.
*cough cough* Best Buy - Monster Cables * cough cough*
cruisin5268d is offline
Old 07-26-2014, 08:53 AM
jz78817
jz78817's Avatar
it gets way worse than that:
http://www.audioadvisor.com/Cardas-C.../#.U9OyyPldViQ
jz78817 is offline
Old 07-26-2014, 12:54 PM
Chromeshadow
Chromeshadow's Avatar
JZ I do not appreciate you putting word in my mouth! That is totally out of line and I expect an apology!
Chromeshadow is offline
Old 07-26-2014, 01:03 PM
jz78817
jz78817's Avatar
I didn't put any words in your mouth.
jz78817 is offline
Old 07-26-2014, 04:10 PM
Chromeshadow
ok then.
oh, BTW:
This is a comment from someone who does not understand the details of audio systems and resorts to snide comments. You should shut up about things you know nothing about! Btw, I have never recommended Monster Cables or $1,000 cables for an automotive sound system. In fact, my point-which you totally reversed is that high ohm speakers will have less loss in the cables, that one reason why I prefer them. To twist this into
is wrong.
Old 07-26-2014, 04:53 PM
jz78817
jz78817's Avatar
Sorry, but I've worked in the field for 17 years. I assure you I do know the "details of audio systems."
You have no knowledge about what I do and do not know. going around yelling at people how they "don't know anything about anything" is not a good way to get your point across.
I NEVER SAID YOU DID!!!!111one
In fact, my point-which you totally reversed is that high ohm speakers will have less loss in the cables, that one reason why I prefer them. To twist this into is wrong.
No, your original point was that higher impedance speakers are better for "clear sound." Here, I'll quote you:
It's easier to get clear sound with a single coil that is 4 ohms or 8 ohms,
I called you on that comment, then you started talking about losses in the speaker wire which I never disagreed with. But the whole thing that kicked off this side-track was where you said:
We can argue all day about electrical theory, proof is in the puddin!
I take issue with a statement like that because it's exactly the same thing people who are pushing ultra-expensive crap will say. "You can't measure a difference, but you sure can hear it!" Which is a load of BS.
If you want to take that as "putting words in your mouth," so be it. The only apology coming from me is to WJBertrand for derailing this thread.
jz78817 is offline
Old 07-26-2014, 08:16 PM
WJBertrand
WJBertrand's Avatar
Got the Kicker subs and door speakers installed today. Had to us the Ford adapter rings for the door speakers an that made it really plug and plant. I was worried about the sub performance but I am happy with the result. The OEMs dual coils may have been a bit louder, but not hugely so, but IMHO they make more noise than sound. The Shelby Kicker's, even attached just to the Shaker amp sound much more thumpy and tight than the OEMs. Combined with the Kicker door speakers, the sound is much clearer, especially at high volumes. In the end, I'm sure adding amps would be a further improvement, but I'm pretty happy with this upgrade for now.
WJBertrand is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Shelby Kicker Door Sub Wiring question
