Mach 460 wiring trouble
Old 12-03-2014, 03:25 PM
CDavis26
CDavis26's Avatar
Default Mach 460 wiring trouble
Hey i have a small issue concerning my 460 mach radio wiring i had a friend remove it and replace it with a aftermarket one, after i found out the quality was better with the 460 and i went to replace it i didnt have the factory plugs, so i bought some ford mercury 460 plugs to replace them but i have no clue how to wire it back correctly the diagrams ive found i dont understand or dont match up..if someone could post a picture of the actual wire harness entering the three plugs for the stereo i would greatly appreciate it
CDavis26 is offline
Old 12-06-2014, 08:06 AM
Epoweredrc
Epoweredrc's Avatar
So you didn't buy the correct harnesses for the stock speakers to all work with the new radio? I have he same system in a 97 Stang and i find the 460 mach system to be a pain cause you need the $50 harness's for everything to still work right.
Epoweredrc is offline
Old 12-07-2014, 07:28 AM
CDavis26
CDavis26's Avatar
Well it would still work right if i knew were each wire went into the back of the plugs. I cant find a picture online showing a stock picture of the wires entering the plugs thay go into tte radio
CDavis26 is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Mach 460 wiring trouble
