2006 mustang GT FACTORY SUBS
Old 10-22-2014, 02:17 AM
Jonny_S197
Jonny_S197's Avatar
Default 2006 mustang GT FACTORY SUBS
hey guys i need help. My mustang has the factory subs in the door pannels. As far as i have read they have their own amp (if im sure) .. They are not working and planning on taking apart my door pannel to see whats wrong. Just seeing if anyone has any info or advice on how to take apart the door pannel. any help would be great thanks.
Jonny_S197 is offline
Old 10-22-2014, 12:16 PM
jz78817
jz78817's Avatar
the door woofers are dual voice coil, 1.2 ohms per coil. The subwoofer amps are inside the kick panels on either side of the car.
jz78817 is offline
Old 10-22-2014, 09:16 PM
Jonny_S197
Jonny_S197's Avatar
Do you have any info on how to take apart the door pannel
Old 10-23-2014, 03:14 AM
ticopowell
ticopowell's Avatar
I'm sure there is a writeup somewhere on the site for taking apart the door. It is fairly easy, If I remember correctly there are 7 small 7mm or 8mm screws around the edges of the door and one in the middle, and there are 2 torx screws, something like t27 but don't quote me on that, these are behind the door handle and the window switch panel(the middle small screw is there too). Pull all the screws, pull the extra triangle plastic piece by the mirror, and then gently lift up on the door. You will have to unplug a light and the cable to open the door(I usually use a screwdriver to help with the cable), and then unplug the subwoofer cables as well. With that done the door panel should be completely free of the door and you can work on the subwoofer. The sub has 8 screws behind the plastic trim panel that just pulls off as well as 1 screw in the back.
Hope that helps.
ticopowell is offline
Old 10-23-2014, 12:06 PM
Jonny_S197
Jonny_S197's Avatar
Hope that helps.
Thanks bro
Old 10-23-2014, 02:15 PM
jz78817
jz78817's Avatar
Originally Posted by Jonny_S197
Thanks bro
here are the screw locations:
jz78817 is offline
Old 10-23-2014, 06:23 PM
Jonny_S197
Jonny_S197's Avatar
Thats really helpful thanks alot guys.
Old 10-25-2014, 01:32 AM
ticopowell
ticopowell's Avatar
The top left holes by where the mirror goes in the picture probably aren't screw holes, They go to the plastic cover for the mirror screws on the door... unless I am remembering wrong.
Have fun!
Old 10-25-2014, 06:03 AM
jz78817
jz78817's Avatar
Have fun!
I think one is a screw hole and the other two are alignment pins for the "shark fin" trim piece, though I could also be mis-remembering.
jz78817 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
svtrosey
SVT Forums
08-15-2015 09:09 PM
daytooday
08-11-2015 09:22 AM
pjrolvrz
08-10-2015 02:10 PM
pjrolvrz
08-10-2015 01:39 PM
Quick Reply: 2006 mustang GT FACTORY SUBS
